Be one of the first to harness the effortless power of AI.
All Aboard! Offboarding and Onboarding Staff
Be sure to check out all of our live and on-demand Smokeball webinars:
Get regular updates, webinar invites and helpful content, delivered directly to your inbox!
This field is required.
Learn more on the Support Hub
Join the Smokeball Community
Learn how to confidently navigate and organize your TemplateLab Library! Join Smokeball Trainer, Nicole Damnitz, for a practical walkthrough of searching and browsing templates, court and authority forms, using folders and shortcuts, and best practices for safely copying and editing documents. This session focuses on organization and everyday use and does not cover automation.
Pre-litigation work still takes longer than it should, not because it’s complex, but because too much of it is done manually. This live webinar introduces Novo inside Smokeball’s Archie Apps. Led by Sam Lombardo, this detailed walkthrough demonstrates exactly how Novo works and how firms can use it to streamline AI-powered workflows in personal injury cases.
Medical record retrieval can quietly drain time, money, and momentum from personal injury cases. In this live webinar, Smokeball and integration partner YoCierge will show you how to bring clarity, speed, and predictability to one of the most critical parts of your PI workflow.
